Themes and a view menu
Love NNW and enjoying the themes, but on both Mac and iOS there is a UI change i would like to suggest to solve a real annoyance:
when you’re looking at a view that Themes style you can’t quickly change the Theme. So you cannot compare themes easily. On the Mac you can bring up the Settings window and change it, thats okay. but only okay
But on iOS it pretty annoying to back out of the article view back out of the articles list, hit the settings button, scroll to the themes list, select from a generically styled list of names. then get out of settings, tap the list of feeds, select an article, and assess whether you like the theme. then maybe repeat if you don’t like the theme. If there was a View menu available from the article view, you could increase/decrease font size and change themes and see the feedback directly. On the mac there should be a Themes submenu in the View menu.
just imho.
thanks!
FWIW, on macOS, there’s a theme picker in the status bar now. I think the status bar is hidden by default; just go to View → Show Status Bar.
Another option than showing the status bar is to customise the toolbar as there’s a theme picker which can be added to it. This is also only for macOS NNW.
I’ve thought about this for a while and haven’t made a decision yet on how to handle this for iOS. The current leading idea is to add a preview to a themes-chooser page where it shows what an article would look like.
A preview suggests a sample piece of pre-defined content that is viewed while switching through themes. As a fussy theme chooser I want to preview with my feeds – viewing content that matters to me.
A thought. As a theme exploring iOS user, the time I’m most likely to want to change a theme is when I have recently changed the theme.
Perhaps theme switching/selection could be a mode? A dismissible UI element, too prominent in normal feed reading use, could be shown temporarily after a theme is changed. Napkin sketch:
[ theme name ] (:check_mark:)
  • Either click the name to change the theme again
  • Or commit to the current theme by hitting the :check_mark:
Once dismissed, it is necessary to go back to settings to change the theme once more.
I’d advocate for a format button (the big A little A) next to the filter button in the article view. with a popover that lets you choose themes but also modify font size and maybe margins.
i find some themes specify font sizes that are too small for my middle aged eyes and the system wide font sizes adjuster doesn’t always affect themes.
actually, that reader mode button is already modifying the view. maybe long pressing it could bring up a formatting popover?
