(I brought this up in Slack, but am bringing it back up here in case it is a larger issue than just me.)
I’m macOS 15.5, running on M4 Pro. I have Version 6.1.9 (6135) installed. Running “Check for updates” says I’m all up to date. No VPN. No Private Relay.
I’m not sure I understand what you’re asking (or, if it is related at all to this issue)? Perhaps you’ll want to start a new topic?
But, just in case, I think NNW for Mac 6.2 works well on macOS 26 but it isn’t for macOS 26. The app’s redesign for Liquid Glass I believe is coming in a future update.
I have no idea why it’s not updating — that’s all in Sparkle code, which isn’t something we touch. Since we have our own fork, it doesn’t update automatically either.
If you go to Preferences > Advanced and switch from Release builds to test builds (or the other way) does it update?
Switching to test builds did the trick. I’m not up-to-date. And I quickly switched back to Release Builds. I like a rock solid NNW experience which it has always delivered!
