NetNewsWire 7.0b1 for Mac
This is the first beta to include the Liquid Glass update! @stuartbreckenridge has done really great work on adopting the new UI.
There are a lot of under-the-hood changes — definitely not just UI changes; there are many code changes to almost every part of the app — so be aware that bugs could appear anywhere.
Please report bugs to the bug tracker (also see the Help menu in NetNewsWire to open the bug tracker) or report them here, preferably in the Beta Testing category. But whatever — please do report any bugs you find, one way or another, however you can. :slight_smile:
To get the update: check for updates in NetNewsWire. If it doesn’t work, see Settings > Advanced and make sure you have Test builds instead of Release builds enabled.
Alternately, you can download the release from the release page on GitHub: Release NetNewsWire 7.0b1 for Mac · Ranchero-Software/NetNewsWire · GitHub
Thanks for your help!
PS If you want to watch our progress, see the NetNewsWire 7 milestone. We will be starting an iOS beta on TestFlight as soon as we get the remaining iOS bugs fixed.
Will NNW 7 only work on macOS 26+? Or is that just a temporary limitation of the beta?
Yes — I meant to mention it and spaced. It does require macOS 26.
Firstly, thank you for this. So far so good, it has been fairly solid (not had any crashes or failures). However, there is a bug related to Themes. I have modified a theme to customise a couple of things (colours, font, etc).
When I restart the app (as in closing down, then starting again) the selected theme is lost and it always chooses the “Default” theme.
I doubt my custom theme is to blame as it works perfectly whilst using the app, but I mention it here, just in case.
So to resume, Theme selections are not maintained over restarts.
Thanks for the beta, looks pretty good so far. However, the Show/Hide Read Articles toggle in the articles list (at the top) does not do anything at the moment.
@mih If you update, you should get 7.0b2 with the fix for hide-read-articles.
I am also seeing the Theme selection bug. Tracked under #4938.
