iPhone Duo
I got my iPhone Duo yesterday and so far so good! The unfolded reading experience with NetNewsWire is really nice. I noticed two small bugs – I think they’re technically not specific to the Duo, but they’re more noticeable in my usage so far:
  1. When unfolded in portrait orientation, the swipe from left edge gesture to reveal the article list only works from along the toolbars, not over the article body. See the screenshot to get what I mean.
  2. If you rotate the device while reading an article, you lose your scroll position. It’s particularly noticeable if you switch between portrait and landscape orientation a few times in a row.
I opened PRs 5506 and 5507 to fix those two issues if that’s helpful.
I also noticed that on the outer display, there’s a bunch of dead space at the top – looks like the app is making space for the top tab bar even when the vertical tab bar is present. I opened issue 5530 and a corresponding PR for that too.
Shout out to @stuartbreckenridge for fixing a few other Duo related bugs too :slight_smile:
